McCoyMotorsports
General Sportbikes This area is made for sportbikes in general. Posts that dont really belong anywhere else besides here. Questions can be answered and addressed to fully understand certain aspects. If your question is Manufacturer specific please post it there.
Sponsored by: ICON Motorsports
BluTek HelmetsSportbikeTrackGearLevel One RacingCycleGear.comMotoworld IncSoupy's Performance British Motorcycle GearSee your ad here!
Old 04-07-2008, 06:00 PM   #1 (permalink)
Gimpdiggity
Valiant Poultry
Gimpdiggity's Avatar
Casino Cash: $107252
Sportbike: 02Ninja250, Yamaha LC50 Champ Scooter
Gimpdiggity is a jewel in the rough Gimpdiggity is a jewel in the rough Gimpdiggity is a jewel in the rough
Default Engine Popping On Deceleration...
Hey everyone.
I've got pod filters, a jet kit, and a straight through 2-1 race exhaust on my Ninja 250. When I'm travelling at high RPMs and then let off the throttle, I get some crackling and sometimes a rather loud popping sound.
It is ONLY when I'm coming down from high (over about 8k) RPMs and it's ONLY when the throttle is completely closed.
Is this something that should be normal considering the modifications I've done to the engine??
I found this online, and it seems to say that this is a normal situation:
Originally Posted by Some Internet Page I Found on Google
Engine backfires: It is normal for many high performance exhaust systems to moderately backfire or pop when the throttle is closed from mid-to-high rpm. In fact, one should expect a well-tuned high performance engine to "pop" and "crackle" when the throttle is closed at high rpm. The popping is a result of the air/fuel mixture becoming very lean when the throttle is closed and the engine is rotating well above idle speed. It is also necessary that the exhaust system have rather open mufflers for this to occur. (No mufflers/headers etc.) Why This (normally) Happens: 1) When the throttle valve is in the idle position, fuel does not flow out of the main system (needle, needle jet, main jet). Fuel is only delivered to the engine by the pilot (idle) system. 2) The combined effect of the closed throttle and elevated engine rpm is to create a fairly strong vacuum in the intake manifold. This vacuum, in turn, causes a high air flow rate through the small gap formed by the throttle valve and carburetor throat. 3) Under these conditions the pilot (idle) system cannot deliver enough fuel to create a normal, combustible air/fuel ratio. The mixture becomes too lean to burn reliably in the combustion chamber. It gets sent into the exhaust system unburned and collects there. 4) When the odd firing of the lean mixture does occur, it is sent, still burning, into the exhaust system where it sometimes ignites the raw mixture that has collected ---- the exhaust then pops or backfires Other possible causes: Air Leaks: Any source of fresh air into the exhaust system can create or worsen the conditions that bring about exhaust popping. The most common entry point is the junction of the header pipes and mufflers. Even a small air leak can dramatically increase the intensity or likelihood of exhaust system popping. A high temperature silicone sealant, as can be found in many auto parts stores, may be used to seal the pipe/muffler junction. Lean Carburetion: While exhaust system popping may be considered normal, it is certainly made worse by an overly lean idle circuit. Be sure that your carburetor's pilot jet is the correct size and that the idle air mixture screw is correctly adjusted before looking for other causes of popping. The procedure for adjusting the pilot circuit is covered in the Tuning Manual. Ignition: If exhaust system popping is very loud, irregular and accompanied by loss of power, then you should suspect that the ignition system is not performing as it should. If, for some reason, the ignition sometimes fires at the wrong time, then exhaust popping can become very energetic (loud). Look for failing high tension leads (plug wires), failing ignition coil(s) and especially switches or connectors as possible causes.
But I would like to get some other's input on it before I just stop worrying about it.
For what it's worth, when I pull the spark plugs they showed a light grayish color. No damage or anything. I can't remember how long they've been in there. I took them out to put the new ones that I just got in. Gray, from what I'm finding, is a relatively okay color...but it does signify running a little lean...
Should I rip the jets out and start messing with them?? The bike pulls hard from idle to top end and doesn't have any stutters or sputters or anything...I THINK that the jetting is done correctly, I messed with it alot last fall...but the popping is kinda messing with my head.
***EDIT***
I just found out that the spark plugs that I have are for cold weather. I should be using some hotter heat range plugs. I just ordered them. Would this have any kind of effect on why that plug is showing that it looks a bit lean??
--In Life, Try To Be The Kind Of Person Your Dog Thinks You Are...
--Colts, 49ers, Lions, Detroit Red Wings, Detroit Tigers, USC Trojans, MSU Spartans, LSU Tigers
--2002 Kawasaki Ninja 250--SV-650 rear shock, Sonic Springs .80kg/mm front springs, ZX-2R graphics, flush mount front signals, tail pod rear signals, Kerker 2-1 race pipe, Factory Pro Stage 3 jet kit, UNI pod filters, ZG Double Bubble, Custom Creations soft vinyl seat cover, Kawi Green rim stripes, carbon brake fluid cap, carbon control levers, No Rear Fender, Yamaha R1 Style Mirrors, V-LEDs.com H4 HID Kit, Nelson Rigg Silver Streak Mini Saddle Bags, Rapid Transit Recon Tank Bag, Various Manufacturers Decals
Gimpdiggity is offline   Reply With Quote
Old 04-07-2008, 06:04 PM   #2 (permalink)
Ozy
New Canadian, frm Nigeria
Ozy's Avatar
Casino Cash: $3365
Sportbike: Yamaha R1
Ozy is on a distinguished road
I'd say thats fairly well normal....
So, how does it go with the mods? still like a 250?
Ozy is offline   Reply With Quote
Old 04-07-2008, 06:14 PM   #3 (permalink)
Gimpdiggity
Valiant Poultry
It's quite a bit quicker, actually...and the suspension mods have made it handle even better than it did before.
Old 04-07-2008, 06:17 PM   #4 (permalink)
Spec-R
Spec-R's Avatar
Casino Cash: $10798
Sportbike: 94 CBR600F2
Spec-R is on a distinguished road
You're kidding, right?
You put a race intake and exhaust on your bike, and you're wondering why it sounds like a race bike?
Spec-R is offline   Reply With Quote
Old 04-07-2008, 06:34 PM   #5 (permalink)
killernoodle
Theres no I in threesome
killernoodle's Avatar
Casino Cash: $45817
Sportbike: 2005 Yamaha FZ6
killernoodle will become famous soon enough
If your bike has an air induction system, thats the sound it makes when its working
After a high throttle application, when transitioning to off throttle, there is a lot of unburnt fuel that gets blown into the exhaust system. The air induction system pumps fresh cold air into the exhaust to ignite this unburned fuel, this is the popping you hear.
If you were running just headers, you would see a sweet flame coming out too
FZ6 moderator
killernoodle is offline   Reply With Quote
Old 04-07-2008, 06:40 PM   #6 (permalink)
Jake
Moderator
Jake's Avatar
Casino Cash: $47969
Sportbike: 04 Kawasaki ZX10R, 02 Honda RC51
Jake is on a distinguished road
Sounds like Kawi's KLEEN Air System. My 10R does the same thing as did my 96 6R.
Motocross / Super Motard Forum Moderator
If you have any questions or concerns, PM me
You start out motorcycling with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
Some people are like slinkies; they're good for nothing but they still bring a smile to your face when you push them down a flight of stairs.
Jake is offline   Reply With Quote
Old 04-07-2008, 07:10 PM   #7 (permalink)
Gimpdiggity
Valiant Poultry
Trust me...I see the flame every time there's a louder pop. It's cool.
Old 04-07-2008, 07:13 PM   #8 (permalink)
Gimpdiggity
Valiant Poultry
Alright everyone...
So after getting in to pull out the other spark plug I noticed that one looked quite a bit more white than gray. From what I know, that means that it's running lean.
So, seeing as I do MOST (probably almost all, 90% or so) of my riding at high RPM, would I be correct in thinking that the culprit is the main jet?? I do my riding at high speed and high RPM because I mainly use the bike to commute on the highway. Very rarely is it being ridden with the RPMs below 6k. Now, because of this I'm guessing that the main jet is the part of the carb that is being used most often...and that since I'm running lean the main jet must be a bit too small.
Should I change out the main jet to a larger size and ride it around and check the plugs again soon, or should I just richen the whole thing from idle to top...bigger main jet, move the c-clip down a half notch...
And also, lastly, correct me if I'm wrong, but having an engine run a bit rich is better than having it running lean, right??
Old 04-07-2008, 07:23 PM   #9 (permalink)
Veefer97
Casino Cash: $63736
Sportbike: 98 900RR
Put a larger main in and after a run check the plugs. The main jet is not shut off in the idle position, it overlaps into the idle and midrange since it is a sloppy fit in the main jet circuit. To fatten the midrange place a shim under the needle. Make sure the shim is flat, if not flaten with hamer before you install.
Veefer97 is online now   Reply With Quote
Old 04-07-2008, 07:29 PM   #10 (permalink)
phail
phail's Avatar
Casino Cash: $30078
Sportbike: 05 zx10r
phail is on a distinguished road
You should really find someone with a wide band o2 sensor or spend 100 bucks on some dyno time at a shop.
1991 Kawasaki Zx6 - Sold
1999 Suzuki GSXR600 - Sold
2005 Kawasaki Zx10r - What the fuck was I thinking.
phail is online now   Reply With Quote
Old 04-07-2008, 07:29 PM   #11 (permalink)
Spec-R
Spec-R's Avatar
Casino Cash: $10798
No. Slightly rich is best for the most power.
Going lean means you blow your engine.
Old 04-07-2008, 07:32 PM   #12 (permalink)
phail
phail's Avatar
Casino Cash: $30078
Sportbike: 05 zx10r
Too rich and youll have gas in the motor oil, though.
Old 04-07-2008, 07:36 PM   #13 (permalink)
Gimpdiggity
Valiant Poultry
You just said the exact same thing that I did...
I said running a bit rich is better than running lean...
Then you said...No, running a bit rich is better than running lean...
Old 04-07-2008, 08:42 PM   #14 (permalink)
yamirider
I want to ride again :(
yamirider's Avatar
Casino Cash: $16233
Sportbike: Sold :(
yamirider is on a distinguished road
The way my JDjetting kit described the range of effect on the different parts of the carb are as follows:
pilot jet closed-1/4 throttle
needle 1/4-3/4 throttle
main jet 2/3-full throttle
If its popping at high rpm throttle off its your pilot jet....but I wouldn't mess with that.
My dirtbike pops constantly....and it runs GREAT. Unless its absolutely excessive backfiring and you start noticing a performance loss I wouldn't mess with it.
I just noticed that you already have a jet kit. You are fine. Don't overthink it.
yamirider is offline   Reply With Quote
Old 04-07-2008, 08:54 PM   #15 (permalink)
Spec-R
Spec-R's Avatar
Casino Cash: $10798
Doh, for some reason I thought you said it backwards.
Need some jeep help, please!!! Ronrdrcr Florida 16 01-05-2008 07:35 PM
How-To's - Performance Tips & Tricks Mr. Lesbian Pocketbikes 1 02-01-2005 12:23 PM
Video of my FIRST jet engine vehicle, a Toyota MR2. Adempha Pictures 18 01-09-2005 11:43 PM
zx9 B1 engine for sale under 10k mile samizx7 ZX-7R 3 10-11-2004 01:21 PM
Genuine Yamaha engine bars and oil changes qualdoth FZ6 0 07-30-2004 09:49 AM
