03-17-2008, 02:30 PM
#1 (permalink)
Valiant Poultry
About How Much Should a Valve Adjustment Cost??
Hey everyone.
I've done pretty much all of the modifications and maintenance on my bike since I got it. However, I've never adjusted the valves.
To be completely honest, I'm not really comfortable doing a procedure like this. I will probably have to bite the bullet and just pay for it to be done.
With that said, does anyone have a ballpark idea of how much a valve adjustment on a Ninja 250 would cost??
Thanks.
In Life, Try To Be The Kind Of Person Your Dog Thinks You Are...
2010 and 2011 BACK TO BACK SBN FANTASY FOOTBALL CHAMPION
49ers, Lions, Detroit Red Wings, Detroit Tigers, MSU Spartans
03-17-2008, 02:45 PM
#2 (permalink)
Superbike Champion
Gameroom cash: $14485
Sportbike: 2006 Yamaha FZ6; 2005 Yamaha YZ250F
The Ninja is a dual OHC engine, so the difficulty of checking the valves is directly proportional to how easy it is to get to the valve cover.
If you can easily access the valve cover and get it off, you can do it yourself in probably an hour. You'd just need the spec (available in your service manual) and a good set of metric feeler guages.
If it needs to be shimmed that is another matter.
03-17-2008, 03:06 PM
#3 (permalink)
Calm like a bomb!
Gameroom cash: $16082
Sportbike: 2002 Honda CBR 954RR (Sold), 2004 GSX-R750
Im kinda in the same boat...
My 954 is due for a valve adjustment, but I'm on the fence about diggin in there.
I have a quote for $250 or so on my bike from a local guy...the dealer wanted around $400.
"Death smiles at us all...all a man can do is smile back and lean it over"
03-17-2008, 03:12 PM
#4 (permalink)
runnin dis bish
Checking to see if they are out of spec is pretty easy. If they actually need adjustment that is a different story. When I lived in VA I had to do mine on my SV. I checked them and had 2 out of spec. I loaded the bike up completely torn apart still and took it to our local small shop and he only charged me $80 (1hr) to reshim the ones out of spec. All he had to do was pull the valve cover and the cams and reshim. I put all the rest of it back together. You might try that to see if you can get a better deal.
03-17-2008, 03:39 PM
#5 (permalink)
Hardass!
Gameroom cash: $23920
Sportbike: 06 Kawasaki ZX-14,05 Kawasaki ZX-10R,97 Kawasaki ZX-7-9R,85 Yamaha Vmax, 98 Honda VFR800
Mine was $300, your's should be half price..lol. Nah I dunno but the rule is true, the more valves, the more money. Imagine the 5 valve exups?
03-17-2008, 04:53 PM
#6 (permalink)
Valiant Poultry
Alright, cool. Thanks guys.
I know of a small shop near where I work, but they don't sell Kawasaki bikes. I may go into there to see if they'll do the work on it anyways. If not, I guess I'll have to give the stealership a call.
03-17-2008, 05:39 PM
#7 (permalink)
If you have the manuals it isn't that hard to do. The manuals coupled with the info at ninja250.net makes it easy and saves you $250.
Started small and lovin' it
03-17-2008, 05:58 PM
#8 (permalink)
World 500 GP Racer
The 250 requires a special valve adjusting tool. You can do without but it is hard. If you drill out the spot welds on the coil bracket you can take the valve cover off without removing the coolant hose. Do a search, there is a 250 club and they have all of the info you need. With the tool it is easy as the valves are adjusted by threaded tapets.
03-17-2008, 11:17 PM
#9 (permalink)
Pit Bike Legend
When I did my 500 it was pretty easy. IIRC they used a threaded adjuster with a locknut. If the 250 is the same anyone with a decent mechanical aptitude could do it. Most of the newer 4cyl bikes are shim under bucket which are about the same work to check, but a whole lot more effort to adjust. I did my ZX-6RR and my YZ426 recently and it's not super difficult, but it is a pretty involved process.
03-17-2008, 11:28 PM
#10 (permalink)
needs another beer
i'd be glad to help if you were closer.
ASMA amateur #121
GF&T wrecking ball
If you don't eat your meat, you can't have any pudding.
03-18-2008, 03:38 AM
#11 (permalink)
American Tart
It cost me a few dozen homemade cookies.
In-house mechanic FTW!
03-18-2008, 07:28 AM
#12 (permalink)
World Superbike Champion
Gameroom cash: $20477
Sportbike: Kawasaki GPz1100 ('96)
The EX250 isn't that difficult, but you do need to be prepared to do it.
The worst part about it, arguably, is using the adjusting tool to get the exact tolerances you need while in such a confined space. It's only an 8-valve twin, but it's a tiny one, and everything's packed together pretty tightly.
And you do need to be prepared. The valve adjustment tool (about $40) is something you'll want to have. I really mean that.
Fortunately, no shims or cam removal nonsense is necessary for the 250's motor.
Originally Posted by Skankhair
Does anyone know how to kill someone with their mind? I'd like to learn how.
The cannons blazing, with their blast the Spanish ship is sinking fast.
03-18-2008, 08:14 AM
#13 (permalink)
Gameroom cash: $10672
Sportbike: 2005 Galaxy Blue Yamaha FJR-1300, 2002 Silver/Black Honda CBR954RR
+1 - it will make the job much easier and faster.
MGM - '05 FJR Pilot, SV-650s rider, CBR 954RR Boy Racer
I've spent a lot of time in my life riding my motorcycle - the rest I've just wasted.
03-18-2008, 12:56 PM
#14 (permalink)
Shop prices vary widely depending on where you are, so no one will be able to give you a definite cost. But the EX250 will be at the bottom of the scale for whatever your local shops do charge. That job will take a good mechanic about an hour and a half, maybe a little less. Where I live that would make it about a $100 job but your prices may vary.
I would ask riders in your area about a good independent shop. The Ninja 250's been around for so long that practically every mechanic has worked on it several times, you don't need to go to a dealer for this. Just find a shop that does good work and doesn't charge a fortune.
03-18-2008, 01:40 PM
#15 (permalink)
Valiant Poultry
Yah, the shop that I was thinking of taking it to is an OLD shop. They sell Yamaha products, and really that's about all. They worked on my old Yamaha bike for dirt cheap...I mean, really, dirt cheap. The big Yamaha dealership in town wanted like $300 to replace the fork seals...this guy did it for $65.
I haven't talked to him yet to see if he works on products OTHER than what he sells. I'm guessing that he does, because there are regularly Harleys parked out back where he keeps the stuff he's working on...but I'm not 100% sure.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
