BluTek Helmets
BikeBanditBluTek HelmetsBritish Motorcycle GearMotoworld IncSoupy's PerformanceMotorcycle.com Classifieds!SportbikeTrackGearGravesMotorsportsSee your ad here!
Old 09-08-2004, 01:52 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
superman89
superman89's Avatar
Casino Cash: $252
Sportbike: '04 Yammy FZ6-N (streetbike), 04' R6 (trackbike), '04 YZ250F (dirtbike)
superman89 is on a distinguished road
Exclamation Contest! Oil Leak and Gas Leak?!?!?!
Anyone heard of Car Talk? The Puzzler? Here's one for the FZ6. So I know there are a lot of bright folks on this forum, so there is bound to be a good answer. Here are three pictures of an oil leak and gas leak that I have had three times now (this is my first time taking the pics). I usually find the oil when I have let the bike sit for two days or more (doesn't happen often). The gas leak I find more often, just dripping. The oil comes out as a ring on the ground (I know why, I am curious what you guys say) and both oil and gas are found under the three "let-off" hoses. In the pic the bike has been moved since yesterday, so the oil leak is over to the side. As you can see - it tends to soak my bike cover too. Well that is all I got - best answer wins my respect!
superman89 is offline   Reply With Quote
Old 09-08-2004, 02:50 PM   #2 (permalink)
WTVa
WTVa's Avatar
Casino Cash: $1455
Sportbike: 04/Yamaha/FZ6
WTVa is on a distinguished road
Good lord thoose are hugs pictures
My guess on the gas is maybe your filling it much or maybe leaving in the garage were it gets hot and then it will overflow(vent) as it should to prevent the gas tank from warping big time from the temp. changes. The oil if its actually oil could also be due to same reason, Or if its something that looks like oil it maybe left over packing grease they but on bikes when shipping them on the boat and its still some under the bike that didnt get washed off during assembly at the dealer.
There is my .02
2004 FZ6/R6 Blue
FAZR6 FE Kit Click |Dual Light MOD Click |R6 Fork MOD|R6 Calipers |LSL Sliders Click |05 Black Rims|Scorpion CF Exhaust|Corbin Seat|TankSlapper Click |Yamaha Lower Cowl |Clears all around W/Intergrated LED Tail Light| TCP Seat Cowl|Puig DS Screen|Painted Hugger/Front Fairing/Side Cowl/Fender|Garmin E-Trex GPS|Galfer Custom SS Lines|Service Manual PDF Download|05-R6 Projector Headlight retro-fit CLICK ME|Moto-Tote to get it around PICs
WTVa is offline   Reply With Quote
Old 09-08-2004, 03:34 PM   #3 (permalink)
sunder74
Casino Cash: $251
Sportbike: 2004 Yamaha FZ6 Blue
sunder74 is on a distinguished road
I agree with WTVa on the gas vent. My 2 cents on the oil is this. I found small oil leaks under my bike every so often. Turned out that the Yamaha tech had lathered so much chain lube on the chain that it was flinging off and getting on the centerstand. After sitting for awhile it would drip off the centerstand.
sunder74 is offline   Reply With Quote
Old 09-08-2004, 05:47 PM   #4 (permalink)
fraggle1
fraggle1's Avatar
Casino Cash: $6803
Sportbike: '01 Aprilia Falco
fraggle1 is on a distinguished road
Yeah, that oil spot looks a lot like a spot I used to get with the sloppy original chain lube, too. It would get all over the sidestand, then drip down when the bike was parked. It left a ring around the footprint of the sidestand.
Anthony
fraggle1 is offline   Reply With Quote
Old 09-08-2004, 05:55 PM   #5 (permalink)
j080808
Sportbike:
j080808 has disabled reputation
When I leave my bike in the sun I get the same thing from the tubes, its normal, should taper off.
j080808 is offline   Reply With Quote
Old 09-08-2004, 06:01 PM   #6 (permalink)
Aenygma
2 As 1
Aenygma's Avatar
Casino Cash: $1024
Sportbike: 2004 Yamaha FZ-6
Aenygma has disabled reputation
Silver Token: SBN Silver Token - Issue reason:   Yellow Token: Yellow SBN Token - Issue reason:
Total Awards: 2
Wow, those are pretty big pictures. It looks to me like the gas leak is it just venting. (which is a good thing)
I Never Use Signatures.
Aenygma is offline   Reply With Quote
Old 09-08-2004, 06:22 PM   #7 (permalink)
YZF600_SILVER_CAT
YZF600_SILVER_CAT's Avatar
Casino Cash: $351
Sportbike: 2003 Yamaha yzf 600r
YZF600_SILVER_CAT is on a distinguished road
Default resized pics for everyone
try these at 800x600
YZF600_SILVER_CAT is offline   Reply With Quote
Old 09-08-2004, 07:23 PM   #8 (permalink)
fuzzy6
fuzzy6's Avatar
Sportbike:
fuzzy6 is on a distinguished road
was one of your questions, why is the oil in the shape of a ring and not a circle? I would say it is from the gas dropping in the middle and keeping the oil separated from the gas.
Blue FZ6
tall windshield
Oxford sports tailpack
fuzzy6 is offline   Reply With Quote
Old 09-08-2004, 08:43 PM   #9 (permalink)
j080808
Sportbike:
Sorry, had to cut my post short before. What WTVa said about the fuel overflow, maybe on the California models that tube goes to the canister. The other 2, one goes to the airbox to drain condensation/oil the other goes to the coolant bottle as an overflow.
Check your airbox for excessive oil, the other two are normal. On bikes w/o sealed batteries you would have a 4th tube for the battery vent!
On a side note, my last bike actually had a plastic plug on the airbox drain that was to be drained every so often. This kept the oil from staining the ground, and of course poison the environment through water run-off blah, blah, blah.................
Old 09-08-2004, 09:22 PM   #10 (permalink)
superman89
superman89's Avatar
Casino Cash: $252
Ok, so thanks for making those pics smaller - They didn't look THAT big when I uploaded. As for the oil thing - I don't know, my bike has over 2,000 miles on it and the center stand looks fine. I have redone the chain with a spray wax at least three time now. Also - I am not at all low "looking" on the dipstick and I can't find where it may be coming from. Not saying that is not a possibility, but I just can't traces it.
As for the gas - this has happened both at a full tank and at a Trip F of 19.8 miles. That makes me go Hmmmm....
And good one to the ol' St. Louis boy - Fizzy 6. That is what makes a ring.
That's my update for now. Later
Old 09-10-2004, 11:11 AM   #11 (permalink)
jrevans
jrevans's Avatar
Casino Cash: $16277
Sportbike: 2004/Yamaha/FZ6
jrevans is on a distinguished road
Blue Token: SBN Blue Token - Issue reason:   Green Token: Green SBN Token - Issue reason:   Yellow Token: Yellow SBN Token - Issue reason:
Total Awards: 3
Default Mine has done the same thing
Everytime that I've carried my FZ6 in my pickup truck across the state (of Pennsylvania), I've seen a similar stain/mark in my truck bed. I don't know if it's from sloshing around or sitting in the sun all day, but it has happened to me too, and looks similar to yours. It is definitely oil, and is under the drain tubes. I've checked the oil and the level appears to be correct, so I just attributed it to being bounced around in my truck.
JimE
Jim's FZ6 webpage
jrevans is offline   Reply With Quote
Old 09-10-2004, 02:19 PM   #12 (permalink)
avsrock78
Sportbike: '04 Yamaha FZ6
avsrock78 is on a distinguished road
Has anyone had a problem with oil leaks or low oil levels in their fz6? I'm just wondering cause last weekend I went on a ride of about 400 miles around Texas. A few days later when I went to wash it, I decided to go ahead and check the oil level since I hadn't done it before. When I checked it, it was 1 quart low and sure enough when I started it and rode it to get some of the water off of it, the oil light came on. I put in a quart and rode it over to the dealership and they took a look and didn't find anything and just told me to keep watching it before and after I ride.
Now according to a friend of mine, BMW bikes burn off a lot of oil and it's not uncommon to be a quart low, but he wasn't too sure my bike should have that same problem (design differences). Has anyone else noticed a low oil level in the first 4000 miles of riding?
Currently I have approx 3200 miles and I did have my first service at 400. So my next one isn't due til 4000
avsrock78 is offline   Reply With Quote
LinkBack to this Thread: http://www.sportbikes.net/forums/fz6/9236-contest-oil-leak-gas-leak.html
93 zx7r Gas Leak - Sportbikes.net This thread Refback 10-06-2007 12:26 PM
