Allstate
GravesMotorsportsTuck & Run Clothing CoAdvanstarMotorcycleShowsBikeBanditBritish Motorcycle GearMcCoyMotorsportsMotoworld IncSee your ad here!
LinkBack (66) Thread Tools Display Modes
Old 08-22-2004, 10:47 AM   60 links from elsewhere to this Post. Click to view. #1 (permalink)
FZ6R
Sportbike: 2004 Yamaha FZ6
FZ6R is on a distinguished road
Default Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?)
mod edit: Since this has got to be such a lengthy thread, and this is the largest single issue that we deal with on our FZ6, I am going to attempt to summurize all the useful information from this thread in a single post. This it in attempt to make it easier for members to get the information they need easier for this issue. I hijacked this first post of this thread to make it easy to find. -jcaesar
Throttle Position Sensor (TPS) Issue Summary
What is the TPS?
Originally Posted by Runner-FZ6
The TPS Sensor is just a potensiometer.
It is actually a variable resistor just like the one found on a Volume control on your stereo system.
The the low side gives abrupt and unpredictable off-spec values, because it is this part of the potensiometer that is mostly used. Simply, this part of the potensiometer is worn out!
In fact Segue00 measured the loss of contact in that area.
The same phenomenon happens when a worn Volume potensiometer causes noise on your speakers.
I am not sure that this is the cause for the "binary" throttle response.
The service manual says that the TPS angle (Page 7-31) should be adjusted so as the TPS voltage should be between 0.63-0.73Volt.
So having a healthy, and properly adjusted TPS, we should measure 0.63 to 0.73 Volts when iddling.
If the value was 0 Volts, yeap that could cause that "on-off" response.
What Does the TPS Look Like?
Here is a bunch of good photos taken by Moldmaker of the TPS. He even included photos of the TPS torn down.
http://forums.sportbikes.net/forums/...&postcount=366
http://forums.sportbikes.net/forums/...&postcount=367
http://forums.sportbikes.net/forums/...&postcount=368
What does the TPS do technically?
Originally Posted by greatzipp's orginal question
I've been thinking about this for a week now and can't figure it out. So someone explain this to me or point out the error in my thinking.
Now, your TPS is desinged to tell the ECU how much your twisting the throttle so that the ECU knows how much fuel your injectors should spit out.
The TPS puts out a steady voltage at idle and increases as your turn the throttle. The voltage coming out of the TPS is translated into a signal by the ECU as to how much gas to inject.
At an idle your TSP puts out a steady .7 volts (about) which translates into throttle closed. Not 100% sure what the voltage is for fully open so let's just say 3volts = fully open. So more volts = throttle open more which = more fuel injected ...... right?????
Now let's say your TPS fails for some reason, doesn't matter what. According to the manual the fail safe for a TPS is to fix it at fully open ..... in this state the bike is still ridable.
But now the ECU thinks that the throttle is fully open so wouldn't it inject the amount of fuel = to WOT?? If the ECU thought the throttle was fully open wouldn't your RPM's stay high even if you let the throttle grip go?? Or would it still be injecting the max full for WOT but because the throttle bodies aren't open the fuel air mix is off so the result would just be really poor gas milage and maybe some julty riding caused by unspent fuel due to incomplete combustion.
Originally Posted by Dr. Honda's Response
Hummm… where to start…
OK… the TPS is only a pawn in the fuel injection game. The real leader is the MAP sensor. (Manifold Absolute Pressure) Yamaha calls it the “Intake Air Pressure Sensor.” This little device looks at manifold vacuum. The manifold vacuum is compared to atmospheric pressure by the ECU, and this will give the ECU the Air density of the incoming air charge. The air density, along with the engine RPM with be taken together, and the ECU will look up the injector pulse length on a look up table. (doing it thousands of time a second) Oh… I should also say that the air intake temp also plays a small part in this too.
The only thing that the TPS is really doing is letting the ECU know if you are opening, or closing the throttle. This is important because on a modern, high performance engine, as you quickly open the throttle you need more fuel than the apparent lode will dictate. (map and rpm look up) This is know as “Tip In Fuel” or as it was known on a carburetor… “The accelerator Pump.” Without the tip in fuel… the engine would (minimum) cough and flame out. (too much air) At worst… the engine would have HORIBLE detonation, (pre-ignition) and burn holes in the tops of the pistons, crush the ring lands, bend the rods, or crush the crank bearings. (lot’s-O-bad stuff)
So… when the ECU can no longer reliably read the TPS, the ECU goes into “limp mode.” Limp mode on our FZ6’s is basically running it in it’s Warm-up mode. The added fuel of the warm-up cycle will keep all the bad stuff listed above from happening. (it’s like in permanent acceleration or "choke on" mode)
OK… we don’t like the crappy fuel economy, the smelly exhaust, or the fouled sparkplugs… but they are cheap compared to a blown engine. Personally I think once it can’t read the TPS it should run a bit leaner, but limit the RPM’s to around 7k.
For more discussion on how the TPS technically works, see this thread:
http://forums.sportbikes.net/forums/...d.php?t=291973
How to Replace the TPS:
FZSilver did a great job of summurizing the replacement of the TPS, complete with photos.
http://forums.sportbikes.net/forums/....php?p=2229422
What are the Symptoms of a Faulty TPS?
  • Stalling
  • Irregual idle
  • RPM Drop while acclerating or trying to maintain a constand speed.
  • Drop in fuel Mileage
  • Poor Throttle Response
How to test the TPS:
Originally Posted by Megatron
To check the TPS values, you have to press and hold SELECT + RESET, then turn the key and keep them pressed for 8 more seconds.
It'll appear dIAg on the display, you can release them now. Afterwards use select until you see a d01 (Diagnostic Mode for the TPS)
Then it should read between 15 and 17 if the throttle is closed,
With the throttle fully open, it should read between 97 and 100.
If the values are over or below those I mentioned, the TPS should be replaced.
To leave the dIAG mode, simply turn the key counter clockwise.
For more discussion on testing TPS, see this post:
http://forums.sportbikes.net/forums/...&postcount=247
Some Notes That You Might Want to Consider:
Originally Posted by segue00
1) Although replacing a faulty TPS may solve the problem, it might be something else that causes the TPS to fail.
2) Some bikes had multiple TPS replacements.
3) Most bikes did not have this problem.
4) Some bikes reportedly that had the TPS symptoms did not get fixed by just replacing the TPS.
5) Going into diagnostics every now and then and making sure that the spec value on the throttle of 16 - 100 percent does not change is one way to monitor whether your TPS is changing.
6) It's still a crap shoot, and the odds are that very few throttle position sensors becomes faulty. At least going by the sampling in this forum and on the current number of complaints in NHTSA reports.
7) At least 1 TPS was installed incorrectly upon replacement. Something to do with the o-ring placement.
8) The original TPS had been superceeded by a revision and carries a new part number.
9) So, if you're going to replace your TPS, at least make sure they don't put in a TPS with the old part number. Or ask for the TPS for a 2006 release model or later if you have an '04 or an '05.
What Actions You Should Take to get Yamaha to Address This Issue:
  • Contact Yamaha Customer Service. We need as many people as possible to contact Yamaha about this issue. Hopefully they will address it and issue a recall.
  • File a complaint with the National Highway Traffic Safety Administration (NHSTA) - For those that are in the U.S.
    http://www.nhtsa.dot.gov/cars/problems
  • For those not in the U.S, please file with your local Traffic Safety Adminstration.
  • Sending your faulty TPS to segue00. segue00 is tearing down the faulty TPS and trying to find the root cause. So far he only has a couple, and hasn't been able to nail down the exact root cause with the few he has.
    Also, Jamez is collecting details to submit to the NHTSA and Yamaha to see if we can push this thing to at least a Technical Bulletin if not a Recall.
    So, if your TPS has been replaced (either by yourself or by a dealer), please PM Jaez the following information:
    1.) Your Name, City, State/Province, Country
    2.) Your FZ6 year
    3.) When was your TPS replaced
    4.) Who replaced your TPS (you/non-dealer or dealer)
    5.) The Part# of your replaced TPS
    6.) Attach a copy of your service receipt (if you can/have it)
    7.) Send me any additional information that I have not asked for that you think would be helpful for this cause
    If you have any questions about gathering all this info to send to Yamaha or NHTSA, please PM Jamez.
What can I do to convince the Dealer to replace the TPS if they say there is nothing wrong with it.
The dealer may not be willing to replace it under warranty, because the fault code is not logged. You can force a fault code by disconnecting the TPS, and then turning on the bike. It should log a Fault Code 15.
Also, have them test the resistance of the TPS and make sure that it is within spec.
What part TPS part number is the latest one that I should install to correct the issue.
The TPS should be replaced with the 3rd Generation part no. 5FL-85885-02-00.
FZ6R is offline   Reply With Quote
Old 08-22-2004, 06:16 PM   #2 (permalink)
JoN31
JoN31's Avatar
Casino Cash: $1151
Sportbike: 2004 yamaha FZ6
JoN31 is on a distinguished road
no problem for me....yet. I have only 2500 km under my belt though
2004 liquid silver FZ6
Motovation frame sliders
Puig double bubble
Clear Alternatives LED tail/signals
FZ6 reflective decals
K&N Air Filter
TCP Rear Hugger
Yamaha Lower Cowl
FAZR6 Fender Eliminator
JoN31 is offline   Reply With Quote
Old 08-22-2004, 06:26 PM   #3 (permalink)
g8torblue
g8torblue's Avatar
Sportbike: 2004 FZ6
g8torblue is on a distinguished road
Originally Posted by FZ6R
I think there might be a problem with that part on our bikes. I'm not sure but I believe the TPS is causing my bike to occasionally stall/drop rpm's every once in awhile. I have read others complaining of these symptoms on the forums and I read about another having to replace that part.
I am with you on this one, I left the bike at the Yami Stealership for 3 days and they said that they could not find anything wrong, with the codes that is.....go figure.
So I said, just give me the bike back and hopefully it breaks down completly and you have to come tow the thing. They said that they had spoken to Yamaha Corp. and they have not come up with anything yet.....oh well.
What counts is not necessarily the size of the dog in the fight - it's the size of the fight in the dog.
g8torblue is offline   Reply With Quote
Old 08-24-2004, 04:32 PM   #4 (permalink)
murphy
murphy's Avatar
Casino Cash: $460
Sportbike: yamaha FZ6 Fazer
murphy is on a distinguished road
i had that problem too at mileage less than 5k. ya.money agent had to came tow the thing away. replace a new throttle body. Problem solve. now as good as new>> reaching 15k
murphy is offline   Reply With Quote
Old 08-24-2004, 06:21 PM   #5 (permalink)
g8torblue
g8torblue's Avatar
Sportbike: 2004 FZ6
I called the dealership today and they said that they spoke to Yamaha Corp. and Yami requested to replace the ignigtion switch and the TPS and it will be in next week. So hopefully this crap goes away sooner than later.
Old 08-24-2004, 11:12 PM   #6 (permalink)
Epee
Superbike Champion
Epee's Avatar
Casino Cash: $868
Sportbike: 2008 Concours14, Triumph Daytona 675
Epee is on a distinguished road
Default Same thing with me!
I did a thread on it back in June?
Stalls, rpm drops, lots of highway rpm stumbles. Couldn't get them to find/fix the problem.
Then one day it stalled and on start up, the check engine light came on for a couple of seconds while still running. That evidently finally left a code. They said they found one TPS code. Replaced it and then all is fine
If you are still limping by with a bad one or suspect a bad one. While cruising just hit neutral, let it stall, ignition off for a moment, clutch drop start up. It resets itself and was fine for a while intermittantly?
Hope they go good on it for you. Just tell them they have had lots of bad ones and just replace the TPS for ya'.
Die Livin'
2008 Kawasaki Concours, Triumph 675, Yamaha FZ6, Suzuki DRZ 400S, Yamaha 225 TTR
Epee is offline   Reply With Quote
Old 08-31-2004, 09:50 PM   #7 (permalink)
g8torblue
g8torblue's Avatar
Sportbike: 2004 FZ6
Default Just An Update
I take the bike to the dealership tomorrow so they can replace the TPS and the ignition sensor, they called Yamaha and they said it was the ignition sensor, but will replace the TPS just for the hek of it, damn right..........if you all have this problem just hassle the delaer to call Yamaha. I DID.....
By the way I have 5280miles on the bike so far, so that might be a round about number for this to happen. Good Luck
p.s. they did not find a error code....but will fix it anyway.
Old 08-31-2004, 10:59 PM   #8 (permalink)
krushchev
Toe Tapper
krushchev's Avatar
Casino Cash: $350
krushchev is on a distinguished road
while coming back from Colorado this past monday, I was experiencing hesitation while accelerating after engine braking. I'm personally suspecting the TPS as well, but I'll have to test it to make certain.
on another note, anyone go over 10000 miles yet? I have about 9600 miles on her now.
2004 Yamaha FZ6 - Galaxy Blue
FAZR6's Fender Eliminator Kit, Laser Extreme Quad Pipes, BMC Air Filter, Puig Light Smoke Windscreen (Thanks DefyInertia!), R6 Front Fork/Brakes Upgrade, Dual Braided Front Brake Lines, FS6 Sliders, Givi Monokey sidecases, Dual Headlight Mod (based on WTV's method), Oxford Heaterz Heated Grips, Watsen Designs Flushmount LED Signals, Bubmrtn's DIY LED Taillight Kit
krushchev is offline   Reply With Quote
Old 08-31-2004, 11:08 PM   #9 (permalink)
ZeuSeason
ZeuSeason's Avatar
Casino Cash: $656
Sportbike: '05 ZX-6R
ZeuSeason is on a distinguished road
Any chance Yamaha will do a recall if this is so predominant?
The first wipe is really an exploratory effort..... so no matter how experienced you think you are, there's still some unexpected shit your are gonna have to deal with.
Grouprider.com <---Get Signed Up! Group Name "The Sportbike Network - Sportbikes.net"
ZeuSeason is offline   Reply With Quote
Old 09-01-2004, 10:26 PM   #10 (permalink)
g8torblue
g8torblue's Avatar
Sportbike: 2004 FZ6
Got the bike back in about 4hrs, after the install of the TPS an the Ignigtion sensor, well it was the whole ignition cause I got a set of new keys for the ignition, which now I have one for the gas cap and the ignition, but the bike rides as if it were new.........without holding down those rpms.
Old 09-08-2004, 04:19 AM   #11 (permalink)
crazymofo
I don't want to grow up!
crazymofo's Avatar
Casino Cash: $456
Sportbike: 2005 Yamaha R1 - Shift Red
crazymofo is on a distinguished road
Unhappy
Yeah, mine is doing it too and it is really pissing me off!! It stalled 16 times on a 100 mile ride and so far Yami said that thet can find nothing wrong. I will keep on them until it is fixed. I talked them into calling the factory a second time. Wish me luck, I am sure I will need it because they said that Yami told them that they know nothing of this problem, BS I say!!!!
crazymofo is offline   Reply With Quote
Old 09-08-2004, 09:45 AM   #12 (permalink)
redhawkphi
redhawkphi's Avatar
Casino Cash: $7211
Sportbike: '01 Aprilia RSVR
redhawkphi is on a distinguished road
what would it take for a recall to take place?
redhawkphi is offline   Reply With Quote
Old 09-08-2004, 01:45 PM   #13 (permalink)
Hagrunimar
Hagrunimar's Avatar
Hagrunimar is on a distinguished road
Where would one go to find TSBs for motorcycles if there was one issued for our bikes? I didn't look very hard but google was on loam for them for motorcycles in general, all the listings were just for cars.
Hagrunimar is offline   Reply With Quote
Old 09-08-2004, 10:11 PM   #14 (permalink)
g8torblue
g8torblue's Avatar
Sportbike: 2004 FZ6
Your best bet is to continue to hound the stealership, the bike is under warranty for atleast a year......I will try to find out from my dealer as to what Yamaha Corp. told them and pass it on to you guys....I know that Yamaha said to replace the Ignition and dealer said we will do the TPS for the hek of it........yeah right...
Old 09-08-2004, 10:15 PM   #15 (permalink)
g8torblue
g8torblue's Avatar
Sportbike: 2004 FZ6
I first told the dealer that I was on this Forum and out of 78 of us or so, we have had about 10 complaints in the stalling department.......My bike got fixed.....Hound Away, $6800and up, is not chump change to me.....
LinkBack to this Thread: http://www.sportbikes.net/forums/fz6/7320-throttle-position-sensor-issues-you-experiencing-poor-idle-mileage-stalls.html
YAMAHA BT1100 Bulldog &bull; Toon onderwerp - gasklep positie sensor in carburateur This thread Refback 10-27-2009 05:30 AM
YAMAHA BT1100 Bulldog &bull; Toon onderwerp - gasklep positie sensor in carburateur This thread Refback 08-20-2009 12:42 AM
YAMAHA BT1100 Bulldog &bull; Toon onderwerp - gasklep positie sensor in carburateur This thread Refback 08-18-2009 12:33 PM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 07-13-2009 01:21 PM
Bike stalled out......need advice - Page 2 - Yamaha FZ6 Forums - International FZ6 Motorcycle Community Forum This thread Pingback 07-09-2009 11:02 AM
yamaha tps | VIRGILIO Ricerca | Web This thread Refback 06-14-2009 07:05 PM
GS/GSX/GSX-R#147: Secondary Throttle Valve Actuator (STVA) Reassembly - Sportbikes.net This thread Refback 04-28-2009 07:42 AM
Choppy throttle from idle... - Page 2 - EastTNriders.com This thread Refback 03-25-2009 08:02 PM
Yamaha 1900 Motorcycle, Yamaha Motorcycle Racing Accessory, Yamaha Vster 1100 Motorcycle Accesories - Hanniganmeadows This thread Refback 03-14-2009 05:08 AM
Testing Kawasaki Coils, Scag Kawasaki 19Hp, Side Car For Kawasaki - Fenderf5512 This thread Refback 03-11-2009 05:58 AM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 01-16-2009 03:08 AM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 01-12-2009 06:51 AM
Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) - Page 28 - Sportbikes.net Post #1 Refback 01-08-2009 07:55 PM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 11-28-2008 01:35 AM
king of moped version 3 - Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135.COM This thread Refback 11-25-2008 10:05 PM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 11-06-2008 01:22 AM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 11-04-2008 10:04 PM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 11-03-2008 10:30 PM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 11-03-2008 11:04 AM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 11-03-2008 10:04 AM
´Ó125X¡£¡£µ½ Shogun SP£¨ÓÐͼ£©£¨ÓÖ¼ÓһЩͼÁË£© - ĦÍгµ×¨Çø - ÂíÀ´Î÷ÑǼÑÀñÖÐÎÄÂÛ̳ This thread Refback 11-03-2008 09:57 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 09-26-2008 11:15 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 09-26-2008 04:09 AM
king of moped version 3 - Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135.COM This thread Refback 09-13-2008 06:20 PM
135 LC 'jerking' This thread Refback 09-08-2008 09:40 PM
135 LC 'jerking' This thread Refback 08-07-2008 10:36 AM
Engine Stalling - Page 2 - RiderForums.com Community This thread Refback 08-06-2008 06:48 PM
135 LC 'jerking' This thread Refback 07-11-2008 12:28 PM
Well.. its not the coils... :( (03 R6 hesitating, stalling... details inside..) : Yamaha R6 Forum: R6MessageNet : YZF-R6 Forums This thread Refback 07-01-2008 11:49 PM
Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135 This thread Refback 06-17-2008 11:12 PM
Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135 This thread Refback 06-13-2008 10:45 PM
Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135 This thread Refback 06-13-2008 12:03 PM
Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135 This thread Refback 06-13-2008 08:09 AM
Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135 This thread Refback 06-13-2008 03:50 AM
Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135 This thread Refback 06-13-2008 03:46 AM
Re:Byk yg kata CDI..tapi..mungkinkah TPS ??? - Forum KOM135 This thread Refback 06-13-2008 03:45 AM
MotoPak Pics - Sportbikes.net Post #247 Refback 06-04-2008 02:19 PM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 05-03-2008 05:20 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 04-18-2008 07:16 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 04-06-2008 06:15 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 04-02-2008 10:59 PM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 04-01-2008 07:34 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 03-29-2008 03:05 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 03-28-2008 05:26 AM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 03-27-2008 11:13 PM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 03-27-2008 03:21 PM
Yamaha Throttle position sensor problem(TPS) - Singapore Bikes Forums This thread Refback 03-27-2008 03:08 PM
Google INTERIA.PL - szukaj: fz6r This thread Refback 03-18-2008 05:15 PM
Sportbikes.net - View Single Post - Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) Post #366 Refback 03-15-2008 12:10 AM
135 LC 'jerking' This thread Refback 02-08-2008 11:26 PM
135 LC 'jerking' This thread Refback 01-30-2008 11:15 PM
135 LC 'jerking' This thread Refback 01-27-2008 10:51 PM
135 LC 'jerking' This thread Refback 01-25-2008 03:32 AM
135 LC 'jerking' This thread Refback 01-22-2008 06:54 AM
135 LC 'jerking' This thread Refback 01-22-2008 06:28 AM
135 LC 'jerking' This thread Refback 01-22-2008 03:37 AM
135 LC 'jerking' This thread Refback 01-22-2008 02:40 AM
Sportbikes.net - Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) This thread Refback 12-30-2007 12:35 PM
07 R1 throttle lag - Sportbikes.net This thread Refback 12-27-2007 12:08 PM
Well.. its not the coils... :( (03 R6 hesitating, stalling... details inside..) - R6Messagenet.com This thread Refback 10-24-2007 12:33 PM
Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) - Page 35 - Sportbikes.net This thread Refback 10-23-2007 09:24 PM
Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) - Page 25 - Sportbikes.net This thread Refback 10-22-2007 12:33 PM
Sportbikes.net - View Single Post - Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) This thread Refback 09-24-2007 11:41 PM
Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) - Sportbikes.net Post #366 Refback 09-23-2007 04:47 PM
Sportbikes.net - View Single Post - Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) Post #367 Refback 09-19-2007 04:35 PM
FZ6 Topics worth linking - Sportbikes.net This thread Refback 09-18-2007 11:11 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
aberr8te
