A little squealing is normal, if it's a lot of high pitched metal-on-metal sounding squealing then that is a telltale sign that the pad is done for and that you've got something other than pad hitting your rotor.
Look at your rotor and look for circular grooves in it that look distinct from other markings on the disc. It's also very easy to check your pads or even remove them so you might as well do this.
If you're scoring the rotor, you better take care of it sooner than later or you risk warping the rotor.
R6 Forks, Calipers, Master Cylinder / Galfer SS Front Lines / Two Brothers M2 VALE Polished Aluminum Exhaust / Yamaha Chin Fairing / PUIG Race Windscreen / TCP Aerodynamics Painted Hugger & Chain Guard / FAZR6 FE / FS6 Frame Sliders / Watsen Design LED R1 Flushmount Signals / Garmin StreetPilot 2610 + RAM Mount / Corbin Saddle
"There are 10 kinds of people in this world, those who know binary, and those who don't."
Use frame sliders. One never knows when a cripple is about.
