Go Back   Sportbikes.net > Sportbikes > Yamaha Sportbikes > FZ6 > FZ6 Mods
FZ6 Mods All exhaust, tire, etc modification discussion
BikeBanditJardineProducts.comAdvanstarMotorcycleShows
Allstate
Motorcycle.com Classifieds!BluTek HelmetsMotoworld IncMcCoyMotorsportsSoupy's PerformanceCycleGear.comSee your ad here!
Old 03-28-2008, 10:58 AM   #1 (permalink)
OneTrack
Superbike Champion
OneTrack's Avatar
Casino Cash: $28646
Sportbike: 2006 Yamaha FZ6
OneTrack is on a distinguished road
Default Rumble FE kit: review
After installing my Scorpion exhaust, I found that my FAZR6 FE kit was indeed compatible, but didn't "connect" to the license plate support kit that was supplied by Scorpion.
After much deliberation, I ordered this kit, as it has the 2 vertical pre-drilled holes at each side that attach directly to the Scorpion's attachment piece:-
http://www.1tail.com/sa/cart/detail.asp?pg={73BD0EBA-CBCA-4A36-9852-41045F1DA0C7}
It is well made, but has two distinct issues that make it a non-starter, imo:-
-It is almost identical in configuration and positioning as the OEM fender (IOW, the license plate will sit just as far our and in the same place as with the OEM fender; FAZR6's FE kit places the license plate about 4" further in, which looks MUCH better).
-The "unique LED license plate light" is useless. It is a tiny LED that mounts through a tiny hole in the angle just above the license plate. It illuminates an area about 2" in diameter. Absolutely useless, so you will have to either install the OEM license plate light or some sort of supplemental lighting to make it legal at night.
I brought this to the supplier's attention, who brought it to the manufacturer's attention, and apparently I'm "the only one to complain" They offered to send me a second LED but I'd have to pay $8.95 shipping. :
Don't bother with this rather expensive substitute for the OEM fender.... Yes, it replaces the OEM fender, but nobody will notice that it's supposed to be a "FE" kit. ;) Go with FAZR6's kit which is superior.
Not recommended unless you prefer steel to plastic.
I solved the "connection" problem with the excellent FAZR6 FE kit by drilling a couple of small holes in both the Scorpion bottom bracket and the FAZR6 bracket and screwing them together. Perfect. :thumbup:
OneTrack is offline   Reply With Quote
Old 03-28-2008, 01:33 PM   #2 (permalink)
CrazyBiker
SuperBike Champion
CrazyBiker's Avatar
Casino Cash: $62743
Sportbike: 07 Black FZ1, 06 FZ6 Converted to newer styling - Black/Blue
CrazyBiker is on a distinguished road
You should have tried this much cheaper eBay Motors: 0405060708 Yamaha FZ 6 FZ6 SILVER Fender eliminator TSM (item 350040308963 end time Mar-30-08 23:44:17 PDT)
07 Raven FZ1 (May 06 2009)
Micron Full System|O2 Elim|Lars Airbox Mod|Ivan's FCE|BMC|CopperDawg Flies|HEL SS Lines,Speed Bleeders|ASV Black Shorties|Rizoma Rearsets|Sargent/Corbin Rider/Pillion|MRA Vario|Throttlemiester|Satan666 Highway Pegs|Reverse Retro Mirrors|Symtec Heated Grips|Marine Powerlet|Integrated Taillight|Arrow Signals|T-Rex Frame,Crashbobbins F/R Axle Sliders|Targa FE|Power Bronze Rear Fender
06 Black FZ6:(July 29 2007) R6S Forks,Speedbleeders,SS Lines,HH Sintered Brake Pads|15T,Speedohealer v3|Laser Extreme Quad,-CAT,K&N,PC3|Puig Light Smoke Racing|06 FZ1 Bar|TS Seat|T-Rex Sliders,Axle Crash Bobbins|FAZR6 FE|Powerlet|Dual Headlight Mod (Xenon Super White)|F/R Arrow Signals|Pod Light Mod|Fiamm HB Lo Tone|Reflective Decals on Frame|Universal RAM Mount|BT-016
CrazyBiker is offline   Reply With Quote
Old 03-28-2008, 01:42 PM   #3 (permalink)
OneTrack
Superbike Champion
OneTrack's Avatar
Casino Cash: $28646
Thanks CB! Ya know...I searched one end of the 'net to the other for a FE kit that satisfied all the criteria that I was looking for:-
-Has upper attachment for Scorpion license plate attachment bracket
-mini LED license plate light that works
-"small holes" for aftermarket LED mini flashers (the FAZR6's has OEM elongated holes)
The FE kit that you found is perfect for my needs. I take back everything I said about you young 'uns this week.
Old 03-28-2008, 02:23 PM   #4 (permalink)
CrazyBiker
SuperBike Champion
CrazyBiker's Avatar
Casino Cash: $62743
You are always Welcome ! BTW, the silver is not the only color. Search on ebay, you will find black, blue and red too ... This newer option rocks if it works and is much cheaper for llike $35 shipped!! I am sure someone else here got it ...
Old 03-28-2008, 02:29 PM   #5 (permalink)
wavex
Mr Crash :(
wavex's Avatar
Casino Cash: $32628
Sportbike: 09 Buell XB12Scg, 05 GSX-R600 Trackbike
wavex is on a distinguished road
Blue Token: SBN Blue Token - Issue reason:   Blue Token: SBN Blue Token - Issue reason:
Total Awards: 2
Weird... I had the scorpions and FAZR FE kit and it worked fine
my videos
wavex is offline   Reply With Quote
Old 03-28-2008, 02:33 PM   #6 (permalink)
CrazyBiker
SuperBike Champion
CrazyBiker's Avatar
Casino Cash: $62743
Ok, making it little bit easy. The blue one is not listed but check in a couple of days.
eBay Motors: 04 05 06 07 08 Yamaha FZ 6 FZ6 Fender eliminator NTS (item 350040757740 end time Apr-01-08 05:46:37 PDT)
eBay Motors: 0405 06 07 08 Yamaha FZ 6 FZ6 BLK Fender eliminator NTS (item 350040756353 end time Apr-01-08 05:40:57 PDT)
eBay Motors: 0405 06 07 08 Yamaha FZ 6 FZ6 red Fender eliminator TSM (item 350041954607 end time Apr-03-08 19:01:43 PDT)
Old 03-28-2008, 02:34 PM   #7 (permalink)
oso2k
R6S Crash Cushion
oso2k's Avatar
Casino Cash: $33731
Sportbike: 07 Yamaha R6S, 05 Yamaha FZ6
oso2k is on a distinguished road
Same here...
I am the unofficial maintainer of the Unofficial FZ6 Compatibility Chart. | I also have a FZ6-R Project/Track Bike. Here's its current status.
My FZ6-R: 05 FZ6|CobraSkinz 03-04 R6 Upper/Lower Cowling & Front Fender|03-04 R6 Fork Mod w/03-04 R6 Front Calipers|EBC Pro-lite Contour Front Brake Rotors|Galfer Stainless Steel Brake 03-04 R6 Brake Lines|Customized FZ6 Fairing Stay to hold 03-04 R6 Front Cowling|PowerCommander III USB|K&N Air Filter|K&N Oil Filter|NGK Iridium Spark Plugs| Motul Full-Synthetic Motor Oil|Custom Machined Setback Plates|Customized FZ6 Shifter Rod|DID -1/+2 520 Conversion|EBC Pro-lite Contour Rear Brake Rotor|Pilot Power 120/70/17-180/55/17|Scorpion Stainless Steel "Race Only" Exhaust
oso2k is offline   Reply With Quote
Old 03-28-2008, 02:56 PM   #8 (permalink)
OneTrack
Superbike Champion
OneTrack's Avatar
Casino Cash: $28646
Ordered!
Old 03-28-2008, 03:03 PM   #9 (permalink)
OneTrack
Superbike Champion
OneTrack's Avatar
Casino Cash: $28646
I think you may have misunderstood what my "issue" was. The FAZR6 FE kit is completely compatible with the Scorpions, if you don't mind the kit bouncing around. The Scorpion kit includes a long, flat bracket that goes from the upper muffler mount to the OEM fender. Scorpion also includes a lower bracket that is meant to screw directly to the OEM fender. The two "ears" that attach to the Scorpion lower bracket is not on the FAZR6 FE kit. Scorpion's main, large "U" shaped bracket that is supposed to replace the large "U" shaped fender support bracket is a bit more flimsy than the OEM part, so the FE kit bounces around quite a bit once the license plate light, license plate and flashers are installed. As I mentioned, I drilled a couple of holes in both the top of the FAZR6 FE and the Scorpion attachment bracket and screwed them together.
I should take some pictures.
Old 03-28-2008, 03:13 PM   #10 (permalink)
wavex
Mr Crash :(
wavex's Avatar
Casino Cash: $32628
Total Awards: 2
I misread sorry so your subframe steal bracket (where the FAZR kit is mounted) is bounding up and down? is that the problem?
I did not use the bracket that comes with the scorpion (or Lasers for that matter) and I don`t have any bouncing around. I did however dremel out a couple of "notches" from the sides of the plastic "arm" coming from right below the brake light, as well as on the side of the license plate light to be able to ziptie the two together.
Anyways, good luck man! and let us know your solution
my videos
Old 03-28-2008, 04:07 PM   #11 (permalink)
OneTrack
Superbike Champion
OneTrack's Avatar
Casino Cash: $28646
The zip-tie solution is a good one...didn't think of that. Being a certified auto mechanic, I tend to look for the more expensive complicated solution instead of the simple, less expensive one.
Anyhow...I'll let you all know how the new FE kit works out.
If FAZR6 is reading this, the only modifications that I would suggest on your FAZR6 FE is some sort of "blanking plate" with a 5/16" dia. hole for mounting after market mini flashers, as well as provision for attaching the upper support brackets that come with most aftermarket exhaust systems. They all seem to be designed to install directly to the OEM fender's vertical "ears" attachment.
Old 03-28-2008, 04:59 PM   #12 (permalink)
wavex
Mr Crash :(
wavex's Avatar
Casino Cash: $32628
Total Awards: 2
I hate cheap solutions only when they look crappy... and this is pretty much invisible
my videos
Old 03-28-2008, 06:48 PM   #13 (permalink)
OneTrack
Superbike Champion
OneTrack's Avatar
Casino Cash: $28646
My front fairings, rear side pods and tool tray all hide a multitude of sins.... ;) Boneman would have a stroke if he saw some of my wiring "solutions".
FZ6 Aftermarket Mods jcaesar FZ6 Mods 195 01-04-2009 11:38 AM
Central CA - Rumble to the Summit June 22 & 23 2007 ES13Raven California 2 06-12-2007 06:14 PM
New Vendor for R6 Fork Mod Spacer Kit? oso2k FZ6 20 06-08-2007 12:14 PM
What words can you make from sportsbikesnet TwistedGray Open Forums 16 06-04-2007 07:42 PM
NightStalkerFX Giveaway! 1 Full LED Kit. New Product! Fred General Sportbikes 182 01-08-2005 10:12 AM
