Originally Posted by kissajew86
i have not gotten a 2nd hid bulb and ballast....so the right side is still halagen....
the right side headlight does not have a cuttoff, so it would be concidered a high beam
So right now your running the right HID unit as your low beam which lights up both projectors is a single H7 bulb size and running a H7 bulb in the right as your high beam that turns on both projectors right ?
If thats the case are you running only the left 2 projectors with you HID setup as your regular headlights and right side if off since its your high beam till you turn on the highbeam switch ?
Sorry for the silly questions thinking through some ideas now that I am embarking on a little project for the winter months.
I just got my 04-05 R6 headlight projectors in yesterday and have them dis-assembled and noticed that they run on 2 single H7 bulbs and are setup from the factory as left as regular headlight and right off till you turn on the highbeams and also the right projectors set it set with different projectors that the left unit to toss a more strait focused beam with no cutoff like the left units. At least this is my learnings so far. so the R6 also is in-flicked with the FZ6 hey one headlight is out syndrome too. problem is they are running 2 H7 bulbs unlike us with H7 on one side and H4 on the other side and without more serious modifications to the projectors you can't have inside projectors on low and outside 2 projectors as highbeams.
