Help With Frame Slider - Sportbikes.net
FZ6/FZ6R If you’re looking for one bike to perform a multitude of missions, look no further. Take it from Cycle World* Magazine - “For a more advanced rider looking for a bike to do it all, there is no other choice.”
User Tag List
post #1 of 10 (permalink) Old 04-02-2007, 02:19 AM Thread Starter
FZ6 Rider
Quoted: 0 Post(s)
Hey all,
Sorry to say I went down today (high sided trying to stop in some gravel, my own stupid fault). Anyways my Uncaged frame slider on the left side bent about 45 degrees. In my quick attempt today I tried to get it off but couldnt. Attached is a pic of it. Does anybody have any recommended ways of getting it off. I was thinking of trying to bend it back to straight, but I am afraid the bolt might break. Then I would be really screwed. Any advice would be greatly appreciated. Thanks.
B Moore
bmoore211 is offline
post #2 of 10 (permalink) Old 04-02-2007, 02:58 AM
segue00's Avatar
Quoted: 1 Post(s)
What do you mean by quick attempt? What have you tried that didn't work? Tools used?
segue00 is offline
post #3 of 10 (permalink) Old 04-02-2007, 03:13 AM
I like curves.
Ducksridingbikes's Avatar
Quoted: 0 Post(s)
wow dude, sorry to hear that, how did that uncaged bend like that??? you probably got a shitty bolt at the first place
Ducksridingbikes is offline
post #4 of 10 (permalink) Old 04-02-2007, 03:33 AM
segue00's Avatar
Quoted: 1 Post(s)
It actually did its job. It took and absorbed the impact by bending without breaking. Hopefully saved the frame from being damaged. Main purpose of a frame slider is to protect during a lowside and tipovers, but this happened during a highside which incurs more impact forces. Bolt bending means that less force was transferred to the bike at impact.
segue00 is offline
post #5 of 10 (permalink) Old 04-02-2007, 03:39 AM
I like curves.
Quoted: 0 Post(s)
The reason i said that is that i was looking at the frame slider tip, and it looks like it didnt take much damage from the friction which means that slider bent with the first impact, i guess we cant really know the physics of the crash but i thought the tip would brake before the bolt bends like that
post #6 of 10 (permalink) Old 04-02-2007, 07:48 AM
Track Junkie
Randomchaos's Avatar
Quoted: 0 Post(s)
Probably doesnt look to scraped up cause he was in gravel, and it sounds like a slower speed highside. I would recommend taking a mallet and trying to straighten it out. Dont think there is anyway to get it off otherwise.
Gear: Scorpion Stinger Jacket, AGV Forza 1pc Suit, Teknic VR-II Gloves, TCX SS Performance 2 Racing Boots, Scorpion EXO-700 Helmet
Bike: Scorpion SS Exhaust, Fender Eliminator, Reflective Rimtape
Randomchaos is offline
post #7 of 10 (permalink) Old 04-02-2007, 07:50 AM
Dirty Sanchez
apor's Avatar
Quoted: 0 Post(s)
i'd recommend that you get an extra large vise grip, clamp it to the slider so that the vise-grip is perpendicular to the way the bolt originally was, and try and twist it out. if you have, or can get, a large pipe wrench, i think it'll be even better. the trick is to twist the bolt so that you're not twisting against the natural direction the bolt would turn to unthread. if in fact you do break it, a machine shop or any competent mechanic should be able to get it out anyway, so it won't be a total loss.
good luck
apor
"Those who sacrifice freedom in the name of security deserve neither."
apor is offline
post #8 of 10 (permalink) Old 04-02-2007, 10:36 AM
Unhelpful Canadian
Binary Jay's Avatar
Quoted: 0 Post(s)
I say take it to your mechanic and let them strip the threads and be responsible for it instead of risking it yourself and having a bike you can't safely ride to get repaired afterwards.
R6 Forks, Calipers, Master Cylinder / Galfer SS Front Lines / Two Brothers M2 VALE Polished Aluminum Exhaust / Yamaha Chin Fairing / PUIG Race Windscreen / TCP Aerodynamics Painted Hugger & Chain Guard / FAZR6 FE / FS6 Frame Sliders / Watsen Design LED R1 Flushmount Signals / Garmin StreetPilot 2610 + RAM Mount / Corbin Saddle
"There are 10 kinds of people in this world, those who know binary, and those who don't."
Use frame sliders. One never knows when a cripple is about.
Binary Jay is offline
post #9 of 10 (permalink) Old 04-02-2007, 01:55 PM
armedeverready's Avatar
Quoted: 0 Post(s)
It would take some time and a good drill with some good drill bits but i would drill the head off the bolt and then get out the vise grips and use them to remove the rest of the bold.
armedeverready is offline
post #10 of 10 (permalink) Old 04-02-2007, 02:00 PM
dagdowell's Avatar
Quoted: 0 Post(s)
This is the best way to go about it as I have experience with pesky screws and bolts on my job and I handle them in the same fashion. just knock the rest of the slider off, then drill into the remaining bolt. then take a tap and dye set and unscrew the bolt. No damage to the original threads!
2005 FZ-6 Mods: Dual Headlight Mod- Clear LED FLushmounts- Clear LED Integrated TL- Motovation Frame Sliders- Puig DS R Windscreen- PIAA Xtreme White plus bulbs- Center stand removed- More to Come
dagdowell is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
'97 F3 Frame Slider Installation Advise? NorthernFirepower Help Me Fix It 4 03-14-2007 10:39 AM
good frame slider? Leb_CRX Performance and Customizing 7 10-11-2004 02:13 PM
Frame Slider delle_76 CBR600RR 1 09-17-2004 07:25 PM
People With The LSL Frame Slider... I have a question. Aenygma FZ6/FZ6R 5 07-24-2004 08:02 PM
Frame slider torque specs... kevinmcdade FZ6/FZ6R 4 07-07-2004 11:40 PM
You may post new threads
You may post replies
Refbacks are Off
