Best way to shorten kickstand - Sportbikes.net
FZ6/FZ6R If you’re looking for one bike to perform a multitude of missions, look no further. Take it from Cycle World* Magazine - “For a more advanced rider looking for a bike to do it all, there is no other choice.”
User Tag List
post #1 of 16 (permalink) Old 05-29-2006, 07:40 PM Thread Starter
Quoted: 0 Post(s)
Well, my FZ6 is nicely lowered, thanks to a works performance shock. Now, I need a shorter kickstand. The only aftermarket stands I've found cost an arm and a leg. Does anyone know of a reasonable priced, shorter kickstand, or should I just cut and reweld the stock kickstand? Thanks!
vtxtreme is offline
post #2 of 16 (permalink) Old 05-29-2006, 07:43 PM
needs another beer
toyotapower's Avatar
Quoted: 0 Post(s)
yeah dude, i'd cut it and reweld it, even if you have someone else do it it's not much work.
ASMA amateur #121
GF&T wrecking ball
If you don't eat your meat, you can't have any pudding.
toyotapower is offline
post #3 of 16 (permalink) Old 05-30-2006, 12:40 AM
greatzippy's Avatar
Quoted: 0 Post(s)
I've always heard once you cut & reweld the sidestand it's never as strong as it was before.
If you must have it done I would say have a pro do it & look into ways of re-enforcing it so you don't end up with probs later on.
Today I met a man, I met a man who wasn't there.
He wasn't there again today. I Wish that he would go away.
greatzippy is offline
post #4 of 16 (permalink) Old 05-30-2006, 12:45 AM
Quoted: 0 Post(s)
Yeah, I second that! I would have them weld a piece of rebar on the back of the stand for reinforcement. Even if it's only 4 or 5 inches long it will have 3 reinforced spots after the cut. The rebar will act as a brace should the kickstand weld break. Although, it shouldn't with the 3 welds distributing the weight.
Waltrip_Racing is offline
post #5 of 16 (permalink) Old 05-30-2006, 12:47 AM
Quoted: 0 Post(s)
i cut a small wedge shape out of the kickstand(as high as i could) and bent it out a little and welded it,smoothed it. it has been like that for a year w/no problems!
juiced_s10_n_ohio is offline
post #6 of 16 (permalink) Old 05-30-2006, 05:41 AM
maste's Avatar
Quoted: 0 Post(s)
I just shortened the kickstand on my wife's GS500F last week. I cut out the portion I figured I'd need to (first went an inch and then tried it out) which ended up being ~ 1.2", then I found some threaded stock that fit inside and cut it to length so that it fit the entire length inside the stand.
I then took it to a local weld shop and for $25 they hooked me up. See pics, if you didn't know it you couldn't tell and as far as strength, with that steel rod in there. I don't think there will ever be an issue.
Whether or not this method will work with the FZ6 stand... don't know but I would imagine it will. I did look at our stand and I see that it does taper down a bit below the spring, maybe just go with a smaller diameter rod on the inside, the welder should still be able to form a bond with the two pieces.
ID:	84801   Click image for larger version
2004 FZ6
"When I'm riding a motorcycle, I'm glad to be alive. When I stop riding my motorcycle, I'm glad to be alive" Neil Peart
maste is offline
post #7 of 16 (permalink) Old 05-30-2006, 07:35 AM
segue00's Avatar
Quoted: 1 Post(s)
They sell length adjustable sidestands, you know.
segue00 is offline
post #8 of 16 (permalink) Old 03-20-2009, 10:44 PM
Quoted: 0 Post(s)
adjustable kickstands
i just lowered my 2001 ZX9R 2.5" and with the kickstand it stands straight up, HELL NO im not doin at, just left it on the rear stand.
yes they do sell adjustable kickstands, but if you have a stand kill switch they wont work. and the cheapest one i found was $140+shipping.
chance1616 is offline
post #9 of 16 (permalink) Old 03-21-2009, 12:48 AM
tubemkr's Avatar
Quoted: 0 Post(s)
Why not just cut it off at the flat pad that rests against the pavement and reweld the pad on? That way the weight of the bike resting on it will simply push down against the pad and not put any side load on your welds?
tubemkr is offline
post #10 of 16 (permalink) Old 03-21-2009, 09:01 AM
gatgatgat223's Avatar
Quoted: 0 Post(s)
my buddy just went through this with his gsxr... we just leaned it up against the fork lift at our shop, took the kickstand off, cut it in half then held the bike where we thought it had the same lean as stock... then cut that much off the stand (1.5" drop ended up being 2" off kickstand) then welded it back together..
we kinda have a little advantage having a shop, welding machine, saw, sanders, forklift, and assorted power tools at our disposal though
"Knowing cops may save you from a backseat ride in a police car, but not an ambulance."
gatgatgat223 is offline
post #11 of 16 (permalink) Old 03-21-2009, 09:39 AM
fz6innh's Avatar
Quoted: 0 Post(s)
This is the best solution yet for the absolute strongest stand when it is done. I would definitely go this route.
*-={FZ1inNH}=-* `09 Cobalt Blue FZ1
*Cortech Sport Saddle and Tail bags**Tank Camera Mount**T-REX Frame Sliders**De-stickered **Two Brothers Racing Slip-on Exhaust **AIS Block Off **LARS Airbox Mod **De-Screened Stock Air Filter**Modded stock rear fender*
fz6innh is offline
post #12 of 16 (permalink) Old 03-21-2009, 10:59 AM
Khyren's Avatar
Quoted: 0 Post(s)
I weld for a living and unless you heat it unreasonably hot, you aren't going to take the temper out of it. A good mig or tig welder with a skilled operator will do this just fine. As far as putting a new pad on, since you have the stock one off there, put a bigger one on there so that it has a bigger footprint and won't sink into the pavement as easily. Just some of my ramblings.
06 FZ6 bone stock minus the dual headlight mod... for now.
Khyren is offline
post #13 of 16 (permalink) Old 03-21-2009, 11:02 AM
World 500 GP Racer
Quoted: 0 Post(s)
With the bike being lowered, is it more difficult to get it up on the center stand?
03 GSF1200
03 SV1000S
fire is offline
post #14 of 16 (permalink) Old 03-21-2009, 11:01 PM
shanec88's Avatar
Quoted: 0 Post(s)
That's right!!! I totally agree, even puddle pusher could weld this up, I can show my 9 yr old daughter with a stick welder and let her do it. We ain't talking about building a bridge, or sending a Space Shuttle up.
Mona Vie ITS(Invite, Taste, Share)
Dist ID# 1162263
shanec88 is offline
post #15 of 16 (permalink) Old 03-22-2009, 09:14 AM
I dunno
joe1971's Avatar
Quoted: 0 Post(s)
^+1, The person doin it wouldn't even have to be good, just mediocre
mods: puig racing screen,Pazo shorties (dark navy), yami comfort seat, led taillight w/integrated turn signals, fazr6 fe kit, dual head light mod, uncaged sliders
Of course i am. yaaaa douchebag! hehe <--- lol hidden message?
Not everyone uses the black/blue forum skin. Ya moron.
joe1971 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
Refbacks are Off
