Removing and installing Swingarm Bearings - Sportbikes.net
FZ6/FZ6R If you’re looking for one bike to perform a multitude of missions, look no further. Take it from Cycle World* Magazine - “For a more advanced rider looking for a bike to do it all, there is no other choice.”
User Tag List
post #1 of 5 (permalink) Old 02-19-2006, 11:35 AM Thread Starter
Quoted: 0 Post(s)
05 FZ6 - need to remove the swingarm bearings for powdercoating the swing arm. How do you remove these and how do you reinstall - are these seriously pressed in or just lightly wedged? I tapped on them a bit with no luck - I figure I will replace with new ones just wanted to know if I needed a bearing press etc...
Many thanks -
Jeff
nolift911 is offline
post #2 of 5 (permalink) Old 02-19-2006, 08:00 PM
Metric's Avatar
Quoted: 0 Post(s)
Many thanks -
Jeff
They will be pressed in. Most times you will not be able to get those bearings out without doing some kind of damage to them. Plan on purchasing a new set and make sure you have someone that can put them in properly. A hammer and a socket are not highly recommended, you should use a press.
'06 Cobalt Blue FJR
What brought me to SBN:
'05 Cerulean Silver/Black FZ6
Metric is offline
post #3 of 5 (permalink) Old 02-19-2006, 08:30 PM Thread Starter
Quoted: 0 Post(s)
Yeah they are cheap so I figured not to be real careful with them - doesn't take much to hose the bearings and get some binding. I did get them out without too much drama. I was looking for a beaing press - since I could use one but have not found one deep/tall enough to get the swign arm under, except for the large hydraulic presses.
Guess I will take it to the dealer for the press in of the bearings -
-Jeff
post #4 of 5 (permalink) Old 02-20-2006, 09:02 AM
Quoted: 0 Post(s)
Pop the bearings in the freezer for a few hours before assembly.It some times will help press in a little easier.
nitro200exc is offline
post #5 of 5 (permalink) Old 02-20-2006, 11:55 AM
Metric's Avatar
Quoted: 0 Post(s)
That helps a little sometimes, but usually you need dry ice to get them cold enough to make a big difference.
'06 Cobalt Blue FJR
Metric is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
Refbacks are Off
