Found this on another forum in AZ. I think I'm legal.
A. A person shall display the license plate or plates as follows:
1. For a motor vehicle, motorcycle, trailer or semitrailer, on the rear.
2. For a vehicle for which two license plates are issued, the vehicle owner shall display either of the following:
(a) One plate on the rear.
(b) One plate on the front and one plate on the rear.
B. A person shall display all license plates as required by subsection A until their lawful use expires or is canceled or revoked. A person shall maintain each license plate so it is clearly legible. A person shall securely fasten each license plate to the vehicle as follows:
1. To prevent the plate from swinging.
2. At a height of at least twelve inches from the ground to the bottom of the plate.
3. In a position to be clearly visible.
http://www.azleg.state.az.us/ars/28/02354.htm
A. A motor vehicle, trailer, semitrailer and pole trailer and any other vehicle that is being drawn at the end of a train of vehicles shall be equipped with at least one tail lamp mounted on the rear. When lighted as required by this article, the tail lamp shall emit a red light plainly visible from a distance of five hundred feet to the rear, except that in the case of a train of vehicles, only the tail lamp on the rearmost vehicle need actually be seen from the distance specified.
B. A tail lamp on a vehicle shall be located at a height of not more than sixty inches nor less than fifteen inches to be measured as provided in section 28-923, subsection B.
C. Either a tail lamp or a separate lamp shall be constructed and placed in a manner that illuminates with a white light the rear license plate and renders it clearly legible from a distance of fifty feet to the rear. A tail lamp or tail lamps together with any separate lamp for illuminating the rear license plate shall be wired to provide that the tail lamp or lamps are lighted whenever the head lamps or auxiliary driving lamps are lighted.
http://www.azleg.state.az.us/ars/28/00925.htm
